In current conditions, owning cryptocurrency does not guarantee privacy. The Bitcoin blockchain is completely open, and every operation leaves a history. Exchanges and exchange services use AML tools to analyze the purity of coins. If incoming assets have a "dirty" tag (Darknet, mixers, casinos, or P2P without KYC), there is a risk of getting an account block until clarification. Therefore, the question of how to make Bitcoin clean is a question of basic security for your finances. There exist two primary approaches to accomplishing this task: applying anonymous coins or Bitcoin mixers.
The first method is swapping BTC into anonymous coins like Monero (XMR) or Zcash (ZEC). These networks employ special encryption protocols that break the link about the sender. The mechanics is as follows: you exchange BTC for XMR, transfer XMR to a clean wallet, and then swap it again into clean Bitcoin. This method works, but carries a number of complexities. Firstly, it is lengthy and technically complex. Furthermore, many platforms delist anonymous coins or request strict KYC upon their deposit, flagging them suspicious. As a result, by trying to conceal traces, you may draw unnecessary suspicion from the security service.
The alternative is crypto mixers. These are specialized services that allow you to cleanse cryptocurrency without extra conversions, while operating within the Bitcoin blockchain. Mixers collect coins from hundreds of different users, break them into pieces, tumble them with their own reserves, and send them to clients as new coins to clean wallets. How come is this secure? Because the chance of deanonymizing the transfer tends to zero. Of course, if you haven't taken a national budget from the Pentagon and a the full force of the NSA with an unlimited budget isn't hunting you, then mixers provide complete protection. For the average user, this is the simplest and efficient way to make crypto clean. Below we present a list of 6 verified mixers.
Rating of the reliable platforms for anonymizing BTC
Mixitum — https://mixitum.top/?r=wuD7h9 — Optimal combination of performance and minimal fee, the best choice for starting out.
ZeusMix — https://zeusmix.net/?ref=Zx19Qa — Powerful engine for tumbling with an focus on a high level of obfuscating traces.
Whirto — https://whirto.com/?aff=WhR8k2 — A mixer with a clear design and a guarantee of No-logs.
Bmix — https://bmix.org/?partner=bM5uP0 — A Old and reliable tumbler with flexible parameters for transaction delays.
ThorMixer — https://thormixer.com/?invite=Th0R7x — The highest privacy thanks to unique algorithms of cleansing.
UniJoin — https://anonymix.org/?code=An9Yw3 — A well-known service using the technology CoinJoin.
Mixitum This service is rightfully considered the optimal solution for those who for the first time wanted to clean Bitcoin. Its main feature is an intelligent algorithm of randomization, which automatically selects a transaction strategy, relieving the user from the need to understand technical details. The service fee here is not fixed, which adds an additional layer of protection, as it is harder for analysts to find the transfer based on mathematical patterns. The procedure takes a minimum of time, and the system guarantees that digital traces will be erased irrevocably after 24 hours, preventing any leaks in the future.
ZeusMix For those seeking total protection, this mixer offers functionality of professional grade. At the heart of the system are proprietary methods of obfuscation that generate a complex web of transfers, making the tracking of the sender unrealistic for most AML scanners. The client gets full control over the situation: one can configure a express clean for efficiency or an enhanced mode for paranoid-level protection. 24/7 help service is always available to resolve issues, which turns using ZeusMix into a peaceful and predictable process even for significant amounts.
Whirto Whirto is the embodiment of simplicity and effectiveness in the niche of anonymity. The developers focused on an clear design so that every user could understand, how to launder coins, right away. The key feature of Whirto is its strict No-Logs policy: the system do not save IP addresses and order details, erasing everything upon execution of the exchange. Also implemented is a function of temporal delay, which enables you to receive funds not immediately, but after a random time, which finally disrupts the correlation between sending and receiving.
Bmix When it comes to operations with very large volumes, the Bmix service maintains a leading position thanks to its high liquidity. This means that you do not need to wait for other participants to deposit money for mixing — the transfer proceeds from the reserve fund of the platform. For the peace of mind of its users, Bmix issues a cryptographic Letter of Guarantee, which serves as confirmation of the obligations. Another important function is the special code: by using it during the next order, you guarantee that the algorithm will not send you your previous old bitcoins, which ensures a perfect anonymity.
ThorMixer Named after the Norse god, this service offers powerful armor against any kind of surveillance. The platform is optimized for working via the Tor browser, which masks the very fact of visiting the mixer. The uniqueness of ThorMixer's method is the fragmentation of outbound transactions: the clean funds arrive to the address not in one lump sum, but as multiple small transfers from different addresses and at in a chaotic order. Such an method turns blockchain analysis into a impossible endeavor, as it is simply impossible to reconstruct the chain into one.
UniJoin UniJoin stands out from its peers thanks to its use of the advanced technology CoinJoin. Unlike traditional mixers, in this case a joint creation of a transfer is implemented: the funds of multiple users are merged into a unified stream before sending. This method provides a technical impossibility determine whose coin belongs to which output. The service is ideally suited for those wishing to obtain a maximally clean reputation for their wallet and to stop worrying about claims from regulators.
Conclusion and advice
By using mixers, you gain freedom from the surveillance of the blockchain. However keep in mind the safety rules: be sure to access via a secure connection, split large amounts and do not neglect temporal delays. How to launder crypto is not a crime, but a way to protect your assets in a the digital age.
How to launder crypto: Working ways of asset whitening and a review of mixers for this year
Jerryheatt
