In current conditions, possession of cryptocurrency does not guarantee privacy. The Bitcoin blockchain is completely transparent, and any transaction preserves a digital trace. Trading platforms and swap services use AML tools to monitor the provenance of coins. If incoming assets have a "dirty" history (Darknet, mixers, casinos, or P2P without KYC), there is a risk of catching an wallet block indefinitely. Therefore, the question of how to make Bitcoin clean is a question of basic security for your wallet. There exist two primary approaches to accomplishing this task: using anonymous coins or mixing services.
One option is swapping Bitcoin into anonymous cryptocurrencies like Monero (XMR) or Zcash (ZEC). These blockchains employ special encryption protocols that hide the link about the source. The mechanics is as follows: you swap BTC for XMR, move XMR to a new wallet, and then swap it again into white Bitcoin. It is reliable, but carries many pitfalls. First of all, it is time-consuming and technically complex. Secondly, many exchanges delist anonymous coins or request strict KYC upon their deposit, considering them suspicious. In fact, by seeking to hide traces, you risk draw additional suspicion from the AML officers.
The alternative is Bitcoin mixers. These are professional services that enable you to launder Bitcoin directly, while operating within the Bitcoin blockchain. Mixers accept coins from many clients, split them into pieces, mix them with their pool, and send them to clients as already clean coins to new addresses. How come is this reliable? Because the chance of tracing the transfer tends to zero. Of course, if you haven't stolen a national budget from the intelligence agencies and a the full force of the NSA with supercomputers isn't hunting you, then mixers provide complete guarantee. For the average user, this is the simplest and most effective method to whiten capital. Further we review a list of 6 verified mixers.
Review of the best platforms for anonymizing cryptocurrency
Mixitum — https://mixitum.top/?r=wuD7h9 — Ideal combination of speed and minimal fee, the best choice for beginners.
ZeusMix — https://zeusmix.net/?ref=Zx19Qa — Advanced algorithm for tumbling with an emphasis on a maximum degree of obfuscating traces.
Whirto — https://whirto.com/?aff=WhR8k2 — A site with a clear design and a guarantee of No-logs.
Bmix — https://bmix.org/?partner=bM5uP0 — A Authoritative mixer with flexible parameters for transaction delays.
ThorMixer — https://thormixer.com/?invite=Th0R7x — Maximum privacy due to unique algorithms of mixing.
UniJoin — https://anonymix.org/?code=An9Yw3 — A popular project using the technology CoinJoin.
Mixitum This service is rightfully is the best choice for beginners who wanted to launder crypto. Its key advantage is an intelligent system of mixing, which independently selects a transaction strategy, relieving the user from the necessity to delve into technical details. The commission here is not fixed, which provides an additional layer of protection, as it is more difficult for bots to find the transfer based on percentage patterns. The procedure takes a minimum of time, and the platform promises that digital traces will be erased irrevocably after 24 hours, preventing any leaks in the future.
ZeusMix For those seeking total privacy, this mixer provides functionality of professional grade. At the core of the system lie unique protocols of obfuscation that create a complex web of transfers, turning the search of the sender unrealistic for most AML scanners. The client gets full control over the process: one can configure a quick mix for efficiency or an enhanced mode for paranoid-level protection. 24/7 support is ready to resolve any questions, which makes using ZeusMix into a peaceful and comfortable process even for large investors.
Whirto Whirto is the embodiment of conciseness and effectiveness in the niche of privacy. The team placed their bet on an clear interface so that every user could understand, how to launder coins, right away. The main trump card of Whirto is its ironclad No-Logs policy: the servers do not record metadata and order details, deleting everything upon execution of the transaction. Also implemented is a function of temporal delay, which allows you to receive funds not instantly, but after a set interval, which completely disrupts the correlation between your input and output.
Bmix When it comes to working with significant volumes, Bmix maintains a leading position due to its high liquidity. This means that you do not need to wait for other participants to add money for mixing — the payout occurs from the reserve fund of the platform. For the peace of mind of its clients, Bmix provides a cryptographic Letter of Guarantee, which is proof of the deal. Another critical detail is the mix-code: by entering it during the next visit, you ensure that the system will not send you your own old coins, which ensures a perfect anonymity.
ThorMixer Taking the name of the Norse god, ThorMixer provides impenetrable protection against any kind of surveillance. The platform is tailored for working via the Tor browser, which masks the very fact of visiting the anonymizer. The distinctive feature of ThorMixer's method is the intelligent splitting of outgoing transactions: the money return to the address not in a single piece, but as multiple small payments from different addresses and at different times. Such an method turns attempts at analysis into a meaningless endeavor, as it is unrealistic to assemble the puzzle back.
UniJoin UniJoin stands apart from its competitors thanks to its use of the advanced technology CoinJoin. Unlike classical mixing, here a joint creation of a transfer takes place: the coins of multiple users are merged into a unified pool before payout. This creates a mathematical impossibility determine whose coin belongs to which output. The service is ideally suited for those wishing to have a maximally clean history for their assets and to stop worrying about claims from regulators.
Summary and advice
By using mixers, you acquire freedom from the all-seeing eye of the system. But keep in mind the nuances: always use via a secure connection, break down large amounts and make use of temporal delays. Cleansing Bitcoin is not a crime, but a tool to preserve your property in a the digital age.
Bitcoin cleansing: Effective ways of anonymization and a review of the best services for this year
Jerryheatt
